Genesis8
Jul 13, 2017Aspirant
Upgrade from RAIDiator 4.1.10 to 5.3.13 on a NV+ (RNV2-S2-0000) ?
Hello,
on the back of the ReadyNAS NV+ (4 drives), I see the P/N RNV2-S2-0000, but another P/N if I search with the string NV+ : RND4000v2.
So is the 5.3.13 firmware for RND4000v2 good for the NV+ ?
If it isnt, what is the last firmware for the NV+ (4 drives) branded RNV2-S2-0000 ?
Thanks in advance.
The labels are confusing you. Your NAS is a sparc platform and it is called an NV+ v1 here. It can only run 4.1.x firmware - the current firmware being 4.1.16.
The v2 you are seeing on the back label means you have "hardware revision v2 of the NV+ v1". An NV+ v2 (arm platform) would have -200 at the end of the part number. Yours has -100.
- Genesis8Aspirant
Thanks for your help, I was able to update to 4.1.16
