jchappy65
Oct 04, 2011Aspirant
resurrecting a RNV2-S2-0000
I found an old RNV2-S2-0000 that a co-worker was throwing out, and I was wanting to reuse it. bad thing is that it was only the box. I would like to know if I could buy the lockable trays for it? also...
mdgm-ntgr
Apr 19, 2012NETGEAR Employee Retired
Did you check the disk using SeaTools. Simply finding it to run "fine" is not enough to verify that the disk is O.K.
Considering the NAS is second hand you might want to try some tests such as the memory test: http://www.readynas.com/kb/faq/hardware/is_there_a_way_i_can_verify_if_my_memory_is_good
