bhpowell
Jan 13, 2017Aspirant
Retrospect "Waiting for Media" backing up to ReadyNAS
I've been using Retrospect on my Windows PC for years. I'm currently at Retrospect 10.5 on Win10 x64. I recently bought my 3rd ReadyNAS, with all three in service. (An NV+, an Ultra 4, and now a 2...
- Feb 02, 2017
Retrospect silently worked the other night, so I wanted to post an update. As I mentioned much earlier in this thread, I found a setting that let me connect as a different user.
In Retrospect 10.5 for Windows, it's here...
Configure -> Backup Sets
Select the backup set you are having issues with, then Properties, then the "Members" tab, then Properties again...
You should see a setting for Automatic Login..., where you can set a username and password.
I'm not sure, yet, if the username/password has to match anything. When I went back to check the settings so I could document it here, I realized I'd mistyped the username, yet it silently worked. Just for fun, I just now tried removing the password, and I should know tomorrow or the next day if it needs that. I suspect not, since my ReadyNAS is configured for anonymous read/write access.
bhpowell
Jan 15, 2017Aspirant
Firmware is 6.6.1.
I'm not sure the problem is unique to Retrospect; it might be an issue for any "scheduled" Windows 10 execution of an application. Unfortunately, I don't know much about how it all works on a Windows.
FramerV
Jan 16, 2017NETGEAR Employee Retired
Hi bhpowell,
Do you have non-Windows 10 computers running the same program?
Can you try adding the Retrospect credential to the Windows 10 credential manager?
Also, can you check with Retrospect support. Maybe they have some inputs regarding Windows 10, OS6 ReadyNAS setup.
Your other ReadyNAS units are running a different OS so we might be able to further isolate it from there.
