Yipyip46
Apr 14, 2025Aspirant
RN-104 NAS
I have 3 x RN-104 Nas units. I have never had any issues accessing them from Windows 10. After being coerced into updating to Windows 11 I can no longer access them. In Windows Explorer i can view t...
- Apr 15, 2025
Hello, I always lock my network connections down with fixed IP addresses. I have solved the issue. The problem was in the Group Settings, in the Lanman Workstation Settings.
Thank you for your reply,
Regards
Ian
Apr 14, 2025Guru - Experienced User
Does using the IP address instead of the hostame work? (\\x.x.x.x)
Yipyip46
Apr 15, 2025Aspirant
Regards
Ian
