TonyT3ch's avatar
TonyT3ch
RN10200 - Not showing Admin Web UI after Factory Reset
I have a RN10200 and was doing a factory reset on the device and the Admin Web UI is not responding. The device is pingable and I can see it in the RAIDar App but the front end ui doesn't load.
  • StephenB's avatar
    What drives are you using?
    How long has it been non-responsive?
    • TonyT3ch's avatar
      TonyT3ch
      I have 2 - 1TB Drives and after performing a factory reset the Admin Web UI stopped working. We tried factory resetting it for a second time but encountered the same results. This has been happening since yesterday, we can ping and the device is visible using the RAIDar APP.
      • StephenB's avatar
        What manufacturer/model?
        Can you download the log zip with RAIDar?
        Can you access the shares with File Explorer (or Finder) after the web UI stops working?  Or does that fail also?
ProSupport for Business
