dshipley
Sep 26, 2018Aspirant
rn104 constantly dropping connection with lun after upgrade to 6.9.4
I have upgraded my RN104 to the latest firmware and now find that my connection to the LUN keeps dropping and reconnecting.
any help would be greatly appreciated.
dshipley
Sep 27, 2018Aspirant
I am wondering if I can down grade the system so that I can at least be able to access the files again?
Sep 27, 2018Guru - Experienced User
The release notes say you can downgrade back as far back as 6.9.0
https://kb.netgear.com/000060110/ReadyNAS-OS-6-Software-Version-6-9-4 wrote:
- Devices updated with 6.9.4 firmware should not be downgraded to firmware versions before 6.9.0.
- evan2Sep 27, 2018NETGEAR Expert
Could do you please enable secure diagnostic mode and PM me 5 digit number? then I remote access to check the issue.
RAIDar Secure diagnostic
https://kb.netgear.com/27391/ReadyNAS-RAIDar-6-0
or enable secure diagnostic in NAS admin GUI =>System=>Settings=>Support- dshipleySep 28, 2018Aspirant
as system contains confidential data I am unable to do this.
I am removing data now and have noticed that the access has improved as I go.
I am again able to attach to the LUN and have backed it up.
Not sure why this made any difference as total data usage is at 5% before removing any data.
- evan2Sep 28, 2018NETGEAR Expert
=> Did data usage is more thean 90%, if data usage > 90%, the performance will very slow, and easy to case filesystem fail,
please remove some data or expand data volume.
