k4heines
Jan 15, 2017Guide
RN104 crashing more frequently
Hello. Here's the problem -- in the last week, my ReadnyNAS 104 has crashed twice. By crash I mean the front panel is unrepsonsive (but the power button is lit), and it's not reachable via SMB, ...
k4heines
Jan 16, 2017Guide
Now my RN104 won't come online at all.
I power cycled it (3rd, maybe 4th, time in last week) because it was unrepsonsive on front panel and by all other means. After restarting, it never came online.
Help - Now what? How can I get this to boot and stay operational? Should I load OS 6.6.0 or some utility on a USB thumb drive and connect it to the front of the ReadyNAS? I'm not sure how resolve this.
(BTW, I looked at the logs the last time it booted, and it was all normal stuff -- antivirus updates, snapshots, the fact that the system rebooted. No db corruption listed.)
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- k4heinesJan 18, 2017Guide
I'm afraid I can't send in the logs. I power cycled twice tonight, both times by unplugging the power cable (last resort, I know). On the first new startup, the front panel showed "Retry Startup 86%". It stayed there for a long time, so I power cycled. The second new startup got to "Fail to startup 98%"
Is there some way I can repair it by starting up off a USB hard drive or thumb drive?
- k4heinesJan 21, 2017Guide
mdgm-ntgr, I tried booting again, but it "failed at startup, 92%". I see that I can create a USB Recoery drive, but only when instructed to do so. Would you recommend that? Note, however, that the arm version linked below is 6.6.0, and my ReadyNAS is running 6.6.1. I was able to verify this with Raidar while it was booting. Can you send me a whatever isntructions/files I need so that I can get up and running again.
http://kb.netgear.com/20684/ReadyNAS-Downloads?cid=wmt_netgear_organic
- k4heinesJan 23, 2017Guide
What should I do, call support? It's been over a year, I'm guessing I'll need to pay for that?
My RN104 has had an issue of freezing on startup after an OS upgrade for the last 9 months or so, maybe since I got it.
- Ki_Adi_MundiFeb 02, 2017NETGEAR Employee Retired
USB recovery is used to fix the boot flash, sounds like your box can boot but can't boot up successfully, so it may not be the boot flash issue, do you still want your data ? if not, you can try a factory default.
