bamcw328i
Sep 22, 2026Aspirant
RN104 data-0 inactive since April, still stuck after PSU fix - need assemble advice
Hi all,
I have a ReadyNAS 104 (firmware 6.10.10) with a 4-bay X-RAID2 setup: two Seagate IronWolf 4TB drives and two WD Red 3TB drives. The 3TB baseline across all four disks forms a RAID5 volume called data-0 (8.17 TB), and the extra capacity on the two 4TB drives forms a separate RAID1 volume (931 GB).
What happened, as best I can reconstruct from the logs:
- On April 27, 2026 at 11:01 AM, the system log shows "Disk in channel 4 (Internal) changed state from ONLINE to FAILED." That drive is one of the two WD Reds. SMART data shows a burst of about 878 read errors on that drive's data-0 partition earlier that same morning, right at the tail end of the partition. No reallocated, pending, or uncorrectable sectors before, during, or since, on any drive.
- - Alert emails have apparently never worked on this box ("Alert message failed to send" recurs in the logs going back to 2016), so nobody knew about the April failure. The volume was presumably running degraded on 3 of 4 drives from that point on.
- - On September 13, 2026, the external power adapter started failing, causing all four drives to drop and reconnect erratically, which pushed the NAS into booting its factory-default recovery image.
- - I replaced the power adapter (correct NU90-9120700-I2, 12V/7A). The NAS now boots its normal OS again, all four physical drives are detected correctly, and a separate small mirror volume auto-repaired and finished resyncing on its own.
- - data-0, the 8.17 TB volume with almost all my data, has never been auto-assembled by mdadm across two separate boots since the PSU was fixed, even though the smaller pools repair themselves automatically. The admin page shows "Remove inactive volumes to use the disk. Disk #3,4."
What I've verified so far:
- All four drives pass SMART self-tests clean, zero reallocated, pending, or uncorrectable sectors.
- - I have not clicked "Remove inactive volumes," Format, New Volume, or X-RAID anywhere.
- - SSH itself fails to start on this box right now (error code 15002030001, and "Connection refused" on an actual attempt).
- - I have full log bundles from before and after the PSU replacement if useful.
What I'm hoping for:
I found a very similar solved thread here on this forum (RN104, disk kicked as non-fresh after a power problem, fixed via tech support mode and mdadm --assemble --really-force --readonly). Before I touch anything, I'd appreciate help confirming whether that's the right first step for my logs, and the correct device list for my array specifically. Since SSH won't start, I understand the path in is tech support mode via the boot menu and Telnet, unless there's a better route.
Thanks so much in advance.
Link to that similar solved thread: https://community.netgear.com/discussions/readynas-use/readynas-104---cannot-access-data---remove-inactive-volumes-to-use-the-disk/2454089
If you like, I can analyze the logs for you. Upload them to cloud storage. Then send me the links via private message (PM) using the envelope icon in the upper right of the forum page. Make sure the permissions are set so anyone with the links can download.
- SandsharkSensei
OK, just to make sure what's going on is understood:
Is data-0 something you actually created, or something that showed up after the failure? It's highly unusual that you would have a volume called data-0 that was ever usable. Normally, data-0 shows up as the name for a part of your data volume when the NAS cannot properly assemble data since two volumes cannot have the same name. When this happens, both data and data-0 are unusable, but both do contain your files -- just not fully assembled in a usable form. Is data showing up in addition to data-0? If not, did you do anything to data, like delete it?
This is not unusual when a power supply fails, though having one dead drive at the time may have made it more likely and/or affect recovery likelihood. Note that by not unusual, I don't mean it happens every time; but it happens enough that it's one of the reasons real backup on a separate device or the web is necessary to fully protect your data.
Letting StephenB analyze your logs is your best next step, but this information may help him.
BTW, SSH may not be working because it's not enabled. But volume recovery is best done from tech support mode anyway, even if SSH works. In tech support mode, the OS has made no attempt to mount the volume.
- bamcw328iAspirant
Thanks for checking, that's a great question. I can answer it directly from the NAS's own logs: "data" carries its own RAID metadata showing a creation date of April 20, 2016, so it's a genuinely separate volume that has existed for about a decade, not something that appeared this month as a fallback naming workaround. Both "data" (931 GB, healthy after a recent resync) and "data-0" (8.17 TB, still inactive) are showing side by side in the interface right now. I haven't deleted anything called "data" or touched it in any way. Getting the full logs ready to send over to StephenB now, thank you both for the help.
Both RAID groups are normally concatenated into a single BTRFS filesystem. It sounds like something failed with the 4x3TB group, so it no longer assembles.
If you are lucky, the group is simply out of sync. You will be able to force the re-assembly, as was done in the thread you reference. But the precise commands need to be tailored to your system (particularly here, when you have multiple RAID groups in the volume).
And of course the cause in your particular case might be different.
bamcw328i: Any luck using the commands I sent you?
- bamcw328iAspirant
Thank you again for the detailed steps. No luck yet, I don't have a Windows machine on hand, so it'll take me a bit of time to procure one before I can attempt anything. Didn't want to leave your check-in unanswered, just may be a while before I'm back with results.
One clarification I'd like to have ready for when I do get to it: should the mount /dev/md127 /data command include -o ro (read-only) on this first attempt, given the two non-fresh disks (sdc3/sdd3)? Want to make sure I can copy everything off before anything writes back to the array.
Thanks again for your patience and help.
- bamcw328iAspirant
One update since my last message: I checked System > Volumes directly, and both data-0 and data are showing a red/inactive status with Free Space: 0, not just data-0. That, plus not having heard back on my earlier question yet, given the two non-fresh disks (sdc3/sdd3), I'm planning to include -o ro on the final mount /dev/md127 /data command on this first attempt, to make sure I can copy everything off before anything writes back to the array. Let me know if there's a reason that's not advisable for this specific case.
- portalmanLuminary
are the forums broken? I seem unable to post new topics
A lot of your recent posts are being caught by the automatic spam filter -no idea why.
- portalmanLuminary
Thx appreciate you checking. I think it’s causes by the bad reputation of my WAN IP address. I connect through rubbish CGNAT so share an IP address with thousands of others. It might be rep, or sheer rate.
im having to VPN to a friends internet to be able to post.
- bamcw328iAspirant
One more data point that might be useful: I checked System > Volumes directly in the admin UI, and both data-0 and data are showing a red/inactive status indicator with Free Space: 0, not just data-0. So it looks like neither piece is currently queryable as a real filesystem right now, which lines up with what I found testing the SMB share, not just data-0 being the problem.
