jungleroger
Dec 01, 2013Aspirant
rn104 ddclient freedns
Hi Guys, Could someone help me, I'm trying to setup DDClient on my 104 to use FreeDNS (afraid.org) I've been using this forum aswell as : afraid.org/scripts/freedns.clients.php But I always get t...
jungleroger
Dec 02, 2013Aspirant
Thanks for the reply,
I've tried those things you suggested but no luck...
I'm starting to think it may the version..
the version available is 3.8.0 and it looks like afraid.org will only work with 3.8.1..
Are there any updates??
***Edit***
I have given up on DDclient (I should be able to use a wget script as a cronjob..)
I have tried to uninstall DDClient, it said it was successful but its still running!?!?
is there a command to properly uninstall the app?
***Edit***
