Brannor
Jul 03, 2017Guide
RN104 Slow Performance since 6.7.4
I upgraded to 6.7.4 on June 19th, and since then accessing anything (ReadyNAS Suirveillance) or the device itself has been really slow. I update to 6.7.5 today and the problem persists, though not a...
azerva
Jul 04, 2017Tutor
Hello there,
I am also experiencing very slow transfer speeds (6-7 MB max). I am not 100% sure, but I aslo think it started around after I updated to 6.7.4 on June 3rd. Updated to 6.7.5 today but no change. I have checked cables and stuff, did a few restarts and tried various files.
My ifconfig reports 1 Gbps speed on the eth1 adapter:
Settings for eth1:
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: external
Auto-negotiation: on
Supports Wake-on: g
Wake-on: d
Link detected: yesAlso tried it from different computers, no difference.
Any ideas how and what I can check?
Thanks,
Alex
evan2
Jul 04, 2017NETGEAR Expert
Please run top command, check CPU and memory loading,
also try to disable IPv6 in NAS admin GUI->Network->eth0 or eth1 setting.
- StephenBJul 04, 2017Guru - Experienced User
Also, I suggest using NasTester to test the speed (from a Windows PC that also is using gigabit ethernet). http://www.808.dk/?code-csharp-nas-performance
Then we compare performance with others here.
- azervaJul 04, 2017Tutor
Hi,
top shows nothing out of the ordinary. IPV6 is disabled since I got the box.
Alex
