Brannor
Jul 03, 2017Guide
RN104 Slow Performance since 6.7.4
I upgraded to 6.7.4 on June 19th, and since then accessing anything (ReadyNAS Suirveillance) or the device itself has been really slow. I update to 6.7.5 today and the problem persists, though not a...
evan2
Jul 04, 2017NETGEAR Expert
Please run top command, check CPU and memory loading,
also try to disable IPv6 in NAS admin GUI->Network->eth0 or eth1 setting.
Jul 04, 2017Guru - Experienced User
Also, I suggest using NasTester to test the speed (from a Windows PC that also is using gigabit ethernet). http://www.808.dk/?code-csharp-nas-performance
Then we compare performance with others here.
