Brannor
Jul 03, 2017Guide
RN104 Slow Performance since 6.7.4
I upgraded to 6.7.4 on June 19th, and since then accessing anything (ReadyNAS Suirveillance) or the device itself has been really slow. I update to 6.7.5 today and the problem persists, though not a...
evan2
Jul 04, 2017NETGEAR Expert
Please run top command, check CPU and memory loading,
also try to disable IPv6 in NAS admin GUI->Network->eth0 or eth1 setting.
azerva
Jul 04, 2017Tutor
Hi,
top shows nothing out of the ordinary. IPV6 is disabled since I got the box.
Alex
- dmacleoJul 04, 2017Guide
are you teamed? I run approx 32 MB/sec onto rn104 with teamed adapter.
- StephenBJul 05, 2017Guru - Experienced User
No point in teaming an RN104 - it's not fast enough to be network-bound.
FWIW, 32 MB/sec is slow for large-file reads. Are you testing writes?
- dmacleoJul 05, 2017Guide
yes these were writes to the raid5 using 4 toshiba 7200rpm 3tb drives.
reads from it to ssd on win10 machine) run around 50-55
writes to the attached 7200usb drive on nas run around 45. reads run around 55-60
I asked about teaming because when I first got unit I had to toss some "green" var speed (up to 5200rpm) drives in it and got same figures (7 or so) initially reported, but after teaming I gained about 5MB (for writes) so about 11-12. read speed also increased but I forget figures.
then when I swapped to 7200rpm drives noticed big difference. so teaming helped a bit, not huge difference, but some.
cannot remember if admin interface/folder access speeds themselves changed or not.
