zeevi
Aug 25, 2017Tutor
RN104 Stuck In Boot Menu Mode/Normal after firmware upgrade 6.6.1
Last time I logged into my RN104, it offered me a FW upgrade to 6.8.0. I accepted. Something went horribly wrong and my NAS became unusable - completely. My data's fine due to having off-site backups...
rampage56
Oct 10, 2017Aspirant
My case is a bit different. I have a ReadyNAS 10400 firmware v6.1.8. I have tried to upgrade it to v6.8.1 (didnt read the documentation first) So after booting, it does not boot. Only booting.... message. If Im going to use USB recovery, what firmware version I should use? 6.2.5 or 6.8.1? So if I flashed the wrong version, whats the best option to do?
Thanks in advance guys
Skywalker
Oct 10, 2017NETGEAR Expert
You should use 6.2.5 to do USB recovery if your system was previously running 6.1.8.
- rampage56Oct 11, 2017Aspirant
@Skywalker
Do you mean even if I have already flashed the latest v6.8.1 which is of course stuck in booting... message.
Boot option is working. I will try flashing v6.2.5. and see the result
- SkywalkerOct 11, 2017NETGEAR Expert
Yes. From the sounds of it the update to 6.8.1 didn't finish because the boot loader didn't get updated. So flashing 6.2.5 should be the proper action.
- NhaajuiceOct 11, 2017Aspirant
If this helps anyone...
- Tried to update (numerous times) from GUI Admin auto-update menu.... FAIL
- Tried to update (numerous times AND tried different versions) by selecting the update from the GUI update menu.... FAIL
- Tried (numerous USB keys) to update from USB... FAIL (got stuck on flashing... however (fortunately) a power off/on recovered back to version 6.4.2.
- Last ditch effort... logged into ReadyCloud (internet), which said that it couldnt access my RN104 without an update - do I want to update (remotely)? I thougth WTH, I have nothing to lose... so I did, and goddamit... it WORKED! Now at v6.8.1
