mocoyn
May 26, 2017Aspirant
RN104 Unable to access admin page - Firmware 6.7.3
Hi After install the firmware 6.7.3 I can't access to admin page with the name of the NAS. I can only access with the IP. Too, I've detected I can't access by FTP after install the firmware. ...
- May 30, 2017
"nas_home" is not a valid hostname, so you'll probably want to rename it to something like "nas-home". See https://en.wikipedia.org/wiki/Hostname#Restrictions_on_valid_hostnames.
JennC
May 26, 2017NETGEAR Employee Retired
Hello mocoyn,
Does it still show on the RAIDar the hostname of the NAS? Can you stil also ping the hostname?
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
Also, which web browser are you using?
Are any other services affected e.g. SMB?- mocoynMay 27, 2017Aspirant
I use Firefox and Chrome. And the service SMB is affected too :-(
This morning, I updgraded to 6.7.4 but the issue persist. I think the new firmware could solution the issue but not :-(
- StephenBMay 27, 2017Guru - Experienced User
Just to clarify: I am thinking all services are working correctly when you use the IP address, but some are not connecting if you use the host name.
Is that a correct summary?
The hostname appear as my "nas_home" and when I try ping to this hostname, it respond correctly.
Appear the next text:
C:\Users\IBM_ADMIN>ping nas_home
Pinging nas_home [192.168.1.251] with 32 bytes of data
Reply from 192.168.1.251: bytes=32 time=1ms TTL=64
Reply from 192.168.1.251: bytes=32 time=2ms TTL=64
Reply from 192.168.1.251: bytes=32 time=3ms TTL=64
Reply from 192.168.1.251: bytes=32 time=3ms TTL=64Ping statistics for 192.168.1.251:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 3ms, Average = 2ms
