mallisette
Jul 13, 2017Aspirant
RN104 Unable to access admin page - Firmware 6.7.5
After firmware 6.7.5 upgrade from 6.7.4, the admin page won't load. I just get ReadyNas Admin page is offline after the loading bar. Have tried various browsers and Mac and Windows all the same. A...
- Jul 14, 2017
After 6.8.0 install and reboot - still no joy, but after a power down (goes off from Midnight until 6am) it's accessable this morning.
Thanks for everyones help.
Mike
mallisette
Yes it does:-
Firmware Updater
This tool can update your system's firmware.
It is intended to run from the main user interface, but it is possible to use it directly from here.
| Current Version: | 6.7.5 |
| Remote Version: | 6.7.5 |
| Image Size: | 66678784 |
| Release Notes: | https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5 |
Or choose a local file to upload:
(this process can take several minutes, so please be patient)
Jul 13, 2017Guru - Experienced User
Good.
Some users have gotten admin access back by over-installing 6.7.5 manually from this page.
Some others reported no success with overinstalling, but they did get access back by installing 6.8.0 beta.
Either way, don't try to install the zip file manually - extract the image from the zip, and select that.
- mallisetteJul 13, 2017Aspirant
Fresh download and install not working for me - happy to try the 6.8.0 beta, where can I download that from?
- StephenBJul 13, 2017Guru - Experienced User
You'll find it here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-8-0-T54-Beta-2/td-p/1307856
- mallisetteJul 14, 2017Aspirant
Mike
