Quandru
Jan 07, 2015Aspirant
RN2120 as a "SAN" for ESXi 5.5 hosts
Hi all, I currently own a RN2120 that i use as a simple NAS for home file storage and I've never had a lick of trouble with it. So much so that I want to see whether another of the same units would...
mdgm-ntgr
Jan 07, 2015NETGEAR Employee Retired
Do you really need the rackmount form factor? If not e.g. the 314 or better yet the 516 would be a much better choice for this.
If you need a rackmount NAS I would go with the 3220 over the 2120 for this.
There are arguments both ways about NFS vs iSCSI. Whichever way you go it is important that you backup your data if your data is important to you. No important data should be stored on just the one device.
There are some steps you should take to configure the NAS correctly for use as a VM datastore.
Welcome to the forum!
