jackburton
Jan 11, 2017Tutor
RN2120v2 - Can't (completely) replicate settings between two readynas using Configuration Backup
Hi all, i have to set up several ReadyNas 2120v2 with same settings, i have to do this in an isolated subnetwork (no internet) so i'm using "Configuration Backup" in System menu. I downloaded the "...
jackburton
Jan 11, 2017Tutor
This is bad
Jan 12, 2017Guru - Experienced User
jackburton wrote:
This is bad
I found it annoying, but not fatal - since I knew what the settings were supposed to be.
https://community.netgear.com/t5/ReadyNAS-Beta-Release/Backup-restore-settings-bug/m-p/1148507/highlight/true#M8769 gives more info on what is restored, but not a lot of details on what isn't. I thought there was at least one other thread on this topic, but I am not finding it now.
- jackburtonJan 13, 2017Tutor
I have to replicate settings over 20+ ReadyNas, I expected something more professional from Netgear.
Btw, i found a bug in the Backup config menu, if I use "custom" selection for the settings i want to save, instead of "everything", i can replicate at least network settings, while host name is always not appllied on the restored machine.
I tried also to manually edit the file in the backup folder, where the host name is mentioned (/tmp/config_restore_info) but nothing changed.
- FramerVJan 15, 2017NETGEAR Employee Retired
Hi jackburton,
Based on the description of the issue that you have provided, I may need to check this with others who can probably assist you and get back to you as soon as possible.
Thanks for your cooperation!
- jackburtonJan 15, 2017Tutor
Thanky you,
Best Regards.
