edecanus
Jun 27, 2017Aspirant
RN31400 iSCSI Sync Writes
Hi... I've refreshed the ReadyNAS disks and upgraded firmware (Factory reset to 6.7.4). I use the ReadyNAS to store active SQL and mail databases, images and disk based backups via iSCSI. I hav...
- Jul 24, 2017
Hello edecanus,
Thanks for the feedback. It does appear the issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
Marty_M
Jun 28, 2017NETGEAR Employee Retired
Hello edecanus,
Firmware version 6.7.5 was officially release you may want to try this version.
Welcome to the community!
Marty_M
- edecanusJun 29, 2017Aspirant
Hi Marty_M and thanks...
There is no change after firmware update. Disks are too busy syncing to process even moderate loads via iSCSI causing iSCSI timeouts where the disk drops.Thanks,
Adrian
- Marty_MJul 03, 2017NETGEAR Employee Retired
Hello edecanus,
Are you working with one iscsi lun? Have you tried creating separate iscsi luns for snapshot, backup and data access? There is a possibility that the NAS is having trouble with work load coming to different process going to single lun.
Marty_M
NETGEAR Community Team- edecanusJul 22, 2017Aspirant
Hi Marty_M,
I did reconfigure iSCSI by moving data for long term storage to a single large LUN. Addiitonal iSCSI were created to segregate the work loads across multiple smaller LUN. This is working well as the ReadyNAS overall can now handle the workload better and I'm see as much as a 20% average increase in throughput.
I did reboot the server after all the configuration changes and data moves were completed when after 12+ hours this action did not complete. I was able to login to the ReadyNAS with limited options (i.e. iSCSI and other "settings" where non-responsive or froze the ReadyNAS session. I was able to launch "scrub". This took about 22 hours without the server connected and resulted in iSCSI and other settings responding as expected.
Thanks for the help!
AdrianHello edecanus,
Marty_M
