BetterDays
Apr 19, 2017Aspirant
RN31400 out of memory error isra.16+31c
Used only as a backup array using second copy pushing to the data to RN31400
jak0lantash
Apr 19, 2017Mentor
Running 6.7.0? If so, issue with quotas on the volume. Disabling quotas and/or updating to 6.7.1 Beta 1 would help.
If not, you'll have to describe the actual issue in more details.
- BetterDaysApr 19, 2017Aspirant
Firmware is 6.4.2. Everthign was fine for about a month then I could not login. This was discovered about 1 month after it stopped working. When booting I get the memeory full error message.
- mdgm-ntgrApr 19, 2017NETGEAR Employee Retired
Can you boot to volume read-only mode and send in your logs (see the Sending Logs link in my sig)?
- BetterDaysApr 23, 2017Aspirant
I got into read-only but not sure how to get the files. I'm a novice with stoarge arrays.
