BetterDays
Apr 19, 2017Aspirant
RN31400 out of memory error isra.16+31c
Used only as a backup array using second copy pushing to the data to RN31400
BetterDays
Firmware is 6.4.2. Everthign was fine for about a month then I could not login. This was discovered about 1 month after it stopped working. When booting I get the memeory full error message.
mdgm-ntgr
Apr 19, 2017NETGEAR Employee Retired
Can you boot to volume read-only mode and send in your logs (see the Sending Logs link in my sig)?
- BetterDaysApr 23, 2017Aspirant
I got into read-only but not sure how to get the files. I'm a novice with stoarge arrays.
- mdgm-ntgrApr 23, 2017NETGEAR Employee Retired
The "Sending Logs" link in my signature explains how to download the logs.
- mdgm-ntgrApr 25, 2017NETGEAR Employee Retired
Update to ReadyNASOS 6.7.1-T252 (Beta 2) and if you still have problems try an OS Re-install. On 6.7 an OS Re-install will disable quotas at the volume level.
