NZpesto's avatar
NZpesto
RN31400 stuck in Booting after 6.4 firmware upgrade
Hi,
Upgraded Firmware via GUI to 6.4.
NAS is now stuck in booting.
Where do I go from here?
Sorry new to Community if this has been covered.
    • NZpesto's avatar
      NZpesto
      Hi,
      Thankyou so much for your reply.
      Sadly I had worked through this prior to posting :(, I have since read through the documents again.
      1 USB does nothing!
      Another USB looks like it may do something however the NAS just turns completely off around 40 to 60 sec!
      If i read the tech note correctly the usd is picky!! Is there a list of preferred usb venders?
      This would help alot.
      Note I can telnet to the nas however it requests a username and password that I do not know, then if I did I would not know what to do!
      Once again thank you for your prompt reply, however can you asist with USB vender or tftp options
      Craig
      • Leia's avatar
        Leia
        NETGEAR Employee Retired
        Prepare the USB
        1. Find a USB that is greater than 256 MB but no more than 32 GB.
        2. Ensure there is only one partition on the USB.
        3. Pre-format that USB as FAT-32.
        4. Identify the drive letter your USB is assigned after formatting.
        Besides these, I advise you to use a USB 2.0 stick. And format this USB stick with the usb recovery tool.
ProSupport for Business
