nybblesandbytes
Oct 20, 2015Star
RN316 randomly freezing shared folder on 6.4.0
Hi, I upgraded a client's RN316 to firmware 6.4.0 about 2 days ago. The firmware update reported successful and all seemed ok for about half a day. Now the primary share (2.7TB) of data, has becom...
- Oct 21, 2015
Do you have ssh enabled? If so, can you go in and run top to see if "[btrfs-cleaner]" shows up and is using lots of CPU? If so, then you may well be experiencing an issue that's been reported in other threads.
nybblesandbytes
Oct 21, 2015Star
Howdy,
thx for the reply.
currently it is switched off in settings, but I can enable it.
Thereafter however, I am at a loss - I wouldn't know how to get in via SSH or where to look for btrfs-cleaner... could you possibly advise me?
Many thanks in advance.
btaroli
Oct 21, 2015Prodigy
http://kb.netgear.com/app/answers/detail/a_id/23096
Once enabled, you ssh into the NAS as "root" user and use the admin password.
Once you have a shell, use the "top" command, and you'll see something like this:
top - 02:07:03 up 1 day, 5:49, 2 users, load average: 1.29, 1.42, 1.68 Tasks: 215 total, 2 running, 213 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.1 us, 25.3 sy, 0.0 ni, 74.5 id, 0.2 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 16324816 total, 15779192 used, 545624 free, 3360 buffers KiB Swap: 2093052 total, 0 used, 2093052 free, 14271244 cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2449 root 20 0 0 0 0 R 100.1 0.0 156:42.25 [btrfs-cleaner] 10075 root 20 0 3121m 275m 21m S 1.0 1.7 41:41.11 /apps/dvblink-tv-server/dvblink_server 15643 root 35 15 1872m 181m 10m S 0.3 1.1 0:49.99 Plex Plug-in [com.plexapp.system] /apps/plexmediaserver/B 17001 root 20 0 28616 3080 2548 R 0.3 0.0 0:30.30 top 20018 btaroli 20 0 263m 13m 10m S 0.3 0.1 0:00.14 /usr/sbin/smbd 2
Notice the "COMMAND" of the first line? That's what you're looking for. :)
To exit top, type "q". To disconnect from ssh session, simply use the command "exit".
If this all sounds scary, maybe wait for Netgear to make suggestions on how to proceed.
- nybblesandbytesOct 21, 2015Star
Thank you, I think I can handle it :)
Even so, I am monitoring now for a while, have had a few hours of stability, so wanting to see if it lasts as things are.
- Jan 17, 2024Retired_Member
