blw
Sep 26, 2017Aspirant
RN3220 unable to boot after power outage
I have a ReadyNAS RN3220 that is unable to boot after a power outage. There is no output on the console connection and I cannot get in to the boot menu with or without disks. The ReadyNAS does not sh...
blw
Sep 27, 2017Aspirant
Hi Sandshark, the NAS was protected by a line-interactive UPS but the UPS was not setup to automatically shutdown the NAS so it shut down suddenly. I have tried booting with no drives but the NAS does not show up in RAIDar and does not allow me to enter the boot menu or perform USB recovery. The power LED flashes green but nothing else.
Sep 27, 2017Guru - Experienced User
IMHO if that resulted in hardware damage, it should be covered by the warranty. You might try support again (and ask to speak to supervisors, etc if necessary).
- SandsharkSep 27, 2017Sensei
It coyuld still be corruption of the internal flash, but a hardware problem does seem more likely. I'm not sure how Netgear could determine itt's from a power interruption unless you told them. From a voltage spike that proceeded one, maybe, but an inline active UPS should take care of that. Other than a voltage spike, the NAS should survive a power outage, so I agree it should be covered under warranty.
- blwSep 28, 2017Aspirant
Thanks for your help. I have esculated the case to a supervisor as suggested, I will update this thread with the outcome for others in a similar situation!
