fwlli
Jun 08, 2012Aspirant
RND2000-100NAS will not boot
We had a major storm last night that took power out for a while. The device was plugged into a UPS. This morning however, I noticed it could not be sen on the network. After a few attempts at restar...
ReadySECURE
Jun 08, 2012Apprentice
If you only purchased it a year ago it should still be under warranty. Don't try the factory reset unless you are willing to purge your data. At this point I would suggest opening a ticket at http://www.readynas.com/support and editing the subject with your case number.
