davwalt
Sep 20, 2017Aspirant
RND2110 v2 - no factory reset
I have a ready NAS Duo rnd2110 v2 with two hard drives installed. I have had it for awhile but turned it off about a year ago and have not used it since. I want to start using again but cannot reme...
Sandshark
Sep 20, 2017Sensei
Since you are not concered about the data on the drives, the easiest solution is to connect them to a PC and remove all partitions. The NAS will then do a factory reset when they are installed. If that does not work, then you may have a corrupt flash and need to do a USB recovery.
