walshlink
Dec 27, 2015Luminary
RNP 6 w/ Xeon CPU and upgraded fans
Changes made to keep RNP 6 cool after upgrading to Xeon CPU: OS: 6.4.2 Beta 1 Installed/Modified: Delta 80x15mm PWM EFC0812DB, 48.8 CFM, 3800 RPM, 41 dBA Noctua 120x25mm 3-pin NF-F12 Ind...
walshlink
Probably was...when I upgraded fans, I probably eff'd it up...so yes, blow/suck air IN...
- viperhansaDec 28, 2015Virtuoso
Hi guys...
If i only want to speed up system fan minimum rpm's? Is that possible?
// Hans
- mdgm-ntgrDec 28, 2015NETGEAR Employee Retired
You could run the echo command walshlink mentioned earlier in the thread or a similar one. His example sets the minimum fan speed to 2000 RPM.
mdgm wrote:You could run the echo command walshlink mentioned earlier in the thread or a similar one. His example sets the minimum fan speed to 2000 RPM.
Hi mdgm,
But that will set both fans to minimum 2000 then?
My cpu temp is good but my system temp is a bit high. So i just want to raise that abit.
// Hans
