walshlink
Dec 27, 2015Luminary
RNP 6 w/ Xeon CPU and upgraded fans
Changes made to keep RNP 6 cool after upgrading to Xeon CPU: OS: 6.4.2 Beta 1 Installed/Modified: Delta 80x15mm PWM EFC0812DB, 48.8 CFM, 3800 RPM, 41 dBA Noctua 120x25mm 3-pin NF-F12 Ind...
viperhansa
Dec 28, 2015Virtuoso
mdgm wrote:That is just an example. You could set it to e.g. 1200 if you prefer. The value you choose must be higher than the default and a realistic value.
:-) I get that mdgm... :-D
But my question is: can i set cpu fan to one minimum value AND system fan to another?
:smileyvery-happy: "Seems like i need to be more clear how i describe my issues" :smileyvery-happy:
Regards
Hans
mdgm-ntgr
Dec 28, 2015NETGEAR Employee Retired
I'm not sure if that min fan speed applies to both fans or not.
Our current desktop systems have one fan, I believe.
