walshlink
Dec 27, 2015Luminary
RNP 6 w/ Xeon CPU and upgraded fans
Changes made to keep RNP 6 cool after upgrading to Xeon CPU: OS: 6.4.2 Beta 1 Installed/Modified: Delta 80x15mm PWM EFC0812DB, 48.8 CFM, 3800 RPM, 41 dBA Noctua 120x25mm 3-pin NF-F12 Ind...
mdgm-ntgr
Dec 30, 2015NETGEAR Employee Retired
You can make your own custom sensors file if you want to do more advanced changes to settings.
The fans will spin up when needed. Though of course if you use a 3rd party CPU then a custom sensors file may be a good idea to have settings tailored to what works well with that CPU. Our sensors files would be designed for stock hardware.
walshlink
Dec 30, 2015Luminary
mdgm,
Are you talking about modifying the system.conf under sensors.d?
