Jenac
Sep 15, 2013Tutor
Router starts rebooting when I enable teaming on RN516
Problem for Adaptive Load Balancing (ALB) on RN516. Setup. Router ASUS RT-AC66N running latest FW, acting as DHCP, most permanent devices have a fixed IP, running normal 1500, not jumbo package. C...
vandermerwe
Sep 15, 2013Master
Does the NAS have a fixed IP address?
You could try disabling GRO in the router - apparently in LAN/ switch control part of router admin, although I believe asus may have removed/ disabled it because of the problems it caused. Check anyway.
Is the anything in the router logs that might give you a clue?
Have you asked the router manufacturer's support, this sounds like a router problem, not a readynas problem?
