Jenac
Sep 15, 2013Tutor
Router starts rebooting when I enable teaming on RN516
Problem for Adaptive Load Balancing (ALB) on RN516. Setup. Router ASUS RT-AC66N running latest FW, acting as DHCP, most permanent devices have a fixed IP, running normal 1500, not jumbo package. C...
Jenac
Sep 16, 2013Tutor
Thanks for the ideas guys!
GS108Tv2 is better for teaming than GS116E (no support for team that requires config on the switch side on that one...).
No logs on the router that helps either. I'll check if more detailed logging can be turned on.
Did have time in the last two weeks to play around. Without teaming everything runs fine, but it would be nice to be able to turn on.
