ThomasNanninga
Nov 03, 2019Guide
RR2304 - System volume root is 91%.
4x2TB NAS with current OS 6.10.2 reports the same warning message on 91% usage as many other users were facing already. According to the info here I have - turned on SSH Service - turned off AntiVi...
- Jan 07, 2020
Finally I could free the OS partition, no more warning messages, thanks for all the help.
I add a small summary of my steps for others that may have a similar problem.
1. Preparations in NAS settings
a. Activate SSH Service with password: System > Settings > Services
b. Turn off AntiVirus
2. SSH login (Windows 10)
ssh root@<nas-ip-address>
Password: NAS Admin password
3. File search
a. Search for any large files >200MB: find /var -type f -size +200M
b. Look into Antivitus definition directory for any temp files: cd /var/lib/clamav
ls -lsh
c. Look into media/USB_HDD_1 (that is my 8TB USB connected HD) folders for any files
Result 3a-c: no large files, no temps, nothing peculiar in USB_...
Some threads can be found here where users had to delete the /clamav tmp files, not in this case.
4. Mount the root partition as mnt to eliminate directories from listing that actually point to the data partition
a. mount --bind / /mnt
b. ls -lsh -> found many chunk-0000x files in the root directory (StephenB telling that this is from PLEX transcoding)
c. Delete files: rm /chunk-00*
Another ls -lsh: all chunk deleted and reduced partition usage from 3,5G to 1G
d. cd //
unmount /mnt
e. Turn on AntiVirus in NAS settings
Retired_Member
Nov 03, 2019You can search large file in root OS partition,the command as below:
find /var -type f -size +500M
- ThomasNanningaNov 05, 2019Guide
Retired_Member wrote:You can search large file in root OS partition,the command as below:
Btw. that command doesn't find anything, only below 100M you get results.
- StephenBNov 05, 2019Guru - Experienced User
Of course it depends on what the underlying problem is. Often it's one or two oversize files - in which case Retired_Member's command is great. In other cases, it's filled with a bunch of smaller files. Did you look in /mnt/media at the USB folders (after using the mount command I posted earlier)?
- ThomasNanningaDec 16, 2019Guide
When trying to save on USB disk I had a system crash with subsequent Hardware replacement. That's why I didn't responde for a while. Thank Good I could recover all data except some movies. Alfer having the new system reallocated to Insight I got 87% volume usage.
The main reason is my Plex application. Out of 1,87GB total I have 800 MB in /data/apps/plexmediaserver/medialibrary/Plex Media Server/Media and 300MB in ../Metadata.
I could delete the Media Library manually and rebuild it. If that ends in the same result, can't I just source this data out of the root file? Or is that path hard-coded in Plex?
