davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
davidr1
I should clarify this ...
davidr1 wrote:The 3100 only received Notification to upgrade to 6.7.1.
Since then all rsync backups fail within a minute
It actually claims 'complete' - but only the folders exist on the backaup - not the contents of those folders.
e.g.
Backing up the /data directory, the backup /data/databse exists but /database is empty on the backup, as are all other folders backed up.
davidr1
May 29, 2017Luminary
Upgrading to 6.7.4 did not change anything.
Whether using rsync and backing up NAS to NAS or NAS to USB, only the folder structure is 'backed up' - no folder contents.
Using rsync to backup a share also does not back anything up.
This has been working properly until the recent FW updates.
Please - can anybody help?
- TeknoJnkyMay 29, 2017Hero
rsync is working for me on all 4 my nas running 674
are you getting any errors in your logs? check your backup setting to see if you have 'on completion send full backup logs'.
If you are getting out of space or write errors, you might try; system > volumes > click gear > balance
- davidr1May 29, 2017Luminary
Thanks for responding.
The settings haven't been changed - they were working for months / years OK
Log reports job completed successfully.
Email shows only data structure:
Successfully completed backup job Pro Daily Data. -------- Backup Job Information -------- Backup Job Name: Pro Daily Data Backup Job Type: Full Protocol: rsync Backup Source: [volume:data]/ Backup Destination: [remote:rsync]/192.168.1.8::USB_HDD_1 Backup Start Time: Tue May 30 2017 8:15:19 Backup Finish Time: Tue May 30 2017 8:15:19 Backup Status: Success -------- Backup Job Log -------- sending incremental file list data/ data/copies_of_usb/ data/database/ data/documents/ data/filing_cabinet/ data/financial/ data/howtos/ data/software/ sent 441 bytes received 56 bytes 994.00 bytes/sec total size is 0 speedup is 0.00
and looking at the backup only shows empty folders.
Each day is a full backup onto an empty drive.
- mdgm-ntgrMay 30, 2017NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
The last firmware we updated rsync was 6.4.1, I think.
