davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
Sharpy
Jun 05, 2017Aspirant
Do you mean a factory reset (format all data gone) or a OS reinstall from the boot menu
- bedlam1Jun 05, 2017Prodigy
Neither
First download OS 6.7.1 then using The Admin page go to System/Settings and use Manual Install Firmware
- Spacemonkey12Jun 05, 2017Star
Is that a recommended procedure
I have no idea (although Netgear warn not to go back) but it worked flawlessly for me and I urgently needed a solution, particularly as 6.7.2 and then 6.7.4 broke Rsync.
Your NAS will of course advise there is an update to 6.7.4, which I am going to ignore and when 6.7.5 emerges I will hold of that too for a few weeks
