davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
Sharpy
Jun 12, 2017Aspirant
Is there an update to this issue it's been a long time now
capaz
Jun 12, 2017Tutor
- Spacemonkey12Jun 18, 2017Star
Is everyone still experiencing this issue
- davidr1Jun 20, 2017Luminary
Aplologies for delayed response - unexpectedly not avaliable.
Is 6.7.5-T299 (Beta 1) recommended to fix this problem? It has not been offered obviously as it is beta nor talked about but a fix is urgently needed?
It says
Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.and I can't afford to introduce other problems.
If it is a known good fix, surely it could say so?
- StephenBJun 20, 2017Guru - Experienced User
What it says is: [Beta 1] Fixed an issue where rsync local-to-remote backup jobs would only back up the top-level folder.
So it fixes that problem, as capaz attests. Is that the problem you have?
As you likely know all ReadyNAS public betas have that warning. I am running 6.7.5-RC1 on my backup NAS, and haven't had any issues. But it is possible that Netgear Support would deny support if you install it.
Thanks StephenB,
Yes, I saw the[Beta 1] Fixed an issue where rsync local-to-remote backup jobs would only back up the top-level folder.
I was anticipating an rsync only fix ... my post was expressed badly (just out of hospital) - I was alluding to the other things in that release potentially causing problems ...
Thanks for your post though, it gives me the confidence to go ahead and install it.
Many thanks and apologies for any confusion.
