davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
capaz
Jun 12, 2017Tutor
davidr1
Jun 20, 2017Luminary
Aplologies for delayed response - unexpectedly not avaliable.
Is 6.7.5-T299 (Beta 1) recommended to fix this problem? It has not been offered obviously as it is beta nor talked about but a fix is urgently needed?
It says
Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
and I can't afford to introduce other problems.
If it is a known good fix, surely it could say so?
