davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
capaz
Jun 21, 2017Tutor
Test post, please ignore. I've tried two times posting to this thread and neither has shown up.
Edit: ...and now it works. weird. sorry.
Jun 21, 2017Guru - Experienced User
Usually that means the forum spam filter triggered for some reason. You can PM me, as I can release it.
- Spacemonkey12Jun 21, 2017Star
I have checked for a update it says no updates available
- davidr1Jun 21, 2017Luminary
Yes, IMHO it's always better if the update is pushed rather than pulled.
Downloaded the ReadyNASOS-6.7.5-x86_64.zip file but:
I use Linux OS (Ubuntu 16.04.2). I have tried uploading from my desktop but get 'Unrecognised server error'.
My usb drives do not have mount points on my pc so are not visible in the Browse window.
Whilst I could put the update file in a share which is mounted on the pc this is all rather 'messy'. OK, so 2 units are Legacy (Pro2 and Ultra2) and one a 31400 but it should not be this 'difficult'.
Any ideas please and may I ask why this update is not pushed? That makes updates far more 'easy'.
- StephenBJun 21, 2017Guru - Experienced User
Netgear always delays putting the new firmware on the auto-update server.
Though they've never said exactly why, my guess is that it gives them a little time to see if there are any unexpected issues before it hits the full installed base.
