davidr1
May 26, 2017Luminary
Rsync broken since 6.7.1 & 6.7.3
The 3100 only received Notification to upgrade to 6.7.1. Since then backing up using rsync sometimes fails within a minute. The Pro received a notification to upgrade to 6.7.3 - not 6.7.1. Sinc...
Jun 22, 2017Guru - Experienced User
davidr1 wrote:
Sounds like we are beta testing before going to release .... <sigh> :-(
It may sound that way, but it is Netgear's usual practice. You can of course wait for it to hit the update server.
davidr1 wrote:
It is odd that on reopening my browser and logging in to Frontview I get the message:
Firmware version 6.7.5 was uploaded and will be installed after you reboot the device <Reboot> <Close>But as my previous post said I got 'Unrecognizable server error' after uploading from my desktop.
Any suggestions please?
Did you reboot the NAS? If so, was 6.7.5 installed?
I haven't seen the unrecognizable server error myself - I upgraded two NAS with no issues.
capaz
Jun 22, 2017Tutor
FWIW, I got the "Unrecognized Server" error, and then the uploaded/reboot prompt dialog. Re-uploaded and got the same result, twice more. Finally, after going in on SSH and confirming that things looked ready to go, I went ahead and rebooted. It did the update and came up on 6.7.5.
RN104, going from 6.7.5-T299
- davidr1Jun 25, 2017Luminary
All units have now been updated to 6.7.5
Superficially, it appears rsync is now working again.
We have scheduled this weekend to thoroughly test every file in the backups with the files in /Data to ensure integrity.
Thanks to those at Netgear who expedited the code.
- Spacemonkey12Jun 25, 2017Star
How will you be checking the integrity of the data
my unit rn104 has also been updated to 6.7.5
my backups do report as successful and do run more than previous firmware releases but I have ran into some errors still
Data stored in home folders didn't backup reported successful , log indicates ACL Errors also
Couldnt gain permission to access home folders inside backup
Hi Spacemonkey12,
Spacemonkey12 wrote:
How will you be checking the integrity of the dataWe have always:
- Done a backup
- Checksummed each file (proprietrary scripted)
- Parrallel run dummy identical transactions on two computers - ensured each result is identical - very time consuming.
- For files such as media files relied only on 2 above as they are not critical.
There are too many files to do this in a short time. So data is always categorized as essential, can be recreated or not important if lost.
We use our golden rules of backups:
- never trust them
- do daily or hourly as required
- every 2nd day
- every week
- every month
This way, to date, we have been able to recover from corrupted files in backups or in use.
We have to provide an audit every time a clients data needs recovering so we have developed many safeguards.
Each to their own needs - this has worked for us and files do get corrupted.
I'm sure others have different methods - you might consider a separate thread on checking the integrity of backups?
Hope this helps.
