937carrera
Mar 07, 2017Aspirant
Rsync difference OS6 v OS 4 Security ?
I seem to be encountering another difference between how OS6 works compared to OS 4. I know I can achieve my objective by using another protocol or swapping source / destination around, but that ...
- Mar 08, 2017
Click on the RN104 share settings, and select "network access". Then click on the "rsync" tab. You enable read/write access for rsync there.
Mar 08, 2017Guru - Experienced User
937carrera
Mar 08, 2017Aspirant
That's great, I have made the change and successfully run backup job :smileyhappy:
It's actually the same as OS 4, buried a little more and my memory had forgotten what I did about 7 years agoi when I set up the Duo's
