dtarin
Sep 21, 2016Luminary
RSYNC does nothing
Man this ReadyNAS 516 has me puzzled.. it's nifty and much faster than my old nvx but man.. simple things just don't work sometimes. Anway.. I'm having trouble doing an rsync of my user folders ...
Sep 24, 2016Guru - Experienced User
dtarin wrote:
Test backups: Not sure what you mean.
What I mean is simple enough. You cannot enable rsync file access for home folders. The option is grayed out.
So that means an rsync backup job cannot have a remote home folder as a either a source or a destination.
dtarin
Sep 24, 2016Luminary
"So that means an rsync backup job cannot have a remote home folder as a either a source or a destination."
Hm.. check this out.
Although you can't enable rsync on home folders, you can still setup an rsync I found out. You can have home folder as aso remote ReadyNAS NVX and destination as a ReadyNAS 516. The readyNAS NVX must have home drive aveilable over FTP (see screenshot).
RSYNC on the 516 can then have the source and destination setup like this. Homes on the ReadyNAS NVX (RAIDiator 4.2.28) are at path /homes/abc123 where abc123 is the same as the login. The destination should be set to local, and just browse and select the user home directory (i.e. /home/abc123).
That worked but as I said, it appears you can't have a true mirror - as deleted files on the source won't be deleted in the destination without being able to turn on "remove deleted files on target". If I can get that work then I'm golden..
- StephenBSep 24, 2016Guru - Experienced User
No. ftp is not rsync.
dtarin wrote:
That worked but as I said, it appears you can't have a true mirror - as deleted files on the source won't be deleted in the destination without being able to turn on ""remove deleted files on target".
That particular option only works with rsync, and that's what you can't use.
There is something you can do -
1. create a backup share on the 516 (perhaps home-backup), and enable rsync for that share.
2. create a backup job on the nvx, and choose "All Home Shares" as the source. Choose remote rsync server as the protocol, and home-backup as the destination path.
That works because the backup job is not using remote home folders at at all (only the local one).
