bbaraniec
May 17, 2011Luminary
SABnzbget+sickbeard+couchpotato reverse proxy https-http
Current setup: HTTP disabled, HTTPS enabled on Pro. On router redirected port 443 to local IP of nas Public share accessible via https://mydomain.com but without forwarding 80 I get timeout. When ...
bbaraniec
May 19, 2011Luminary
Sorry it seems to easy in my head since I know configuration of my lan. I will try to explain it better this time.
I'm taking about two things:
1.HTTP to HTTPS redirect:
- lets say I have domain bartek.com (actually there is one but it's not mine)
- in Frontview I have disabled HTTP and enabled HTTPS on standard 443 port
- on router I have configured two rules:
- all traffic that comes on WAN 443 redirect to LAN NAS IP 443
- all traffic that comes on WAN 80 redirect to LAN NAS IP 443
- now I go to https://bartek.com and I land in webshare https://bartek.com/shares
- but if I type http://bartek.com instead being redirected to https://bartek.com and then to https://bartek.com/shares I get error message saying try "bla bla try https://my Nas local IP
- if I disable rule redirecting 80 to 443 if you try HTTP the communication will be refused that it
What I want to achieve is when you try HTTP you will always get redirected to HTTPS
2.ReverseProxy
- SABnzb is running on port 8080 HTTPS
- SickBeard is running on port 8081 HTTP no SSL support
- CouchPotato is running on port 5000 HTTP no SSL support
So instead of redirecting few ports and accessing http://bartek.com:8080 I want to access those services http://bartek.com/sabnzb or http://bartek.com/sickbeard
But on top of that I want to use HTTPS for all services and that's why I asked about reverse proxy from HTTPS -> HTTP.
2.ReverseProxy
