bbaraniec
May 17, 2011Luminary
SABnzbget+sickbeard+couchpotato reverse proxy https-http
Current setup: HTTP disabled, HTTPS enabled on Pro. On router redirected port 443 to local IP of nas Public share accessible via https://mydomain.com but without forwarding 80 I get timeout. When ...
TeknoJnky
Jul 25, 2011Hero
all that stuff sounds way too complicated...
why don't you simply port map the programs you want in your router then add the ports to your url
https://bartek.com:8080/sabnzbd/
http://bartek.com:8081/sickbeard/
http://bartek.com:5000/couchpotato/
- SABnzb is running on port 8080 HTTPS
- SickBeard is running on port 8081 HTTP no SSL support
- CouchPotato is running on port 5000 HTTP no SSL support
