bbaraniec
May 17, 2011Luminary
SABnzbget+sickbeard+couchpotato reverse proxy https-http
Current setup: HTTP disabled, HTTPS enabled on Pro. On router redirected port 443 to local IP of nas Public share accessible via https://mydomain.com but without forwarding 80 I get timeout. When ...
bbaraniec
Jul 25, 2011Luminary
sphardy wrote: Unfortunately not all web apps work well with reverse proxying. There's some more info here that might help: http://wiki.slimdevices.com/index.php/C ... cumentRoot
Else - try setting up a subdomain and redirecting that to SBS as I know this works. eg if you setup the subdomain sbs.mydomain.com - your setup becomes:
<VirtualHost *:80>
ServerName sbs.mydomain.com
ProxyPass / http://localhost:9000/
ProxyPassReverse / http://localhost:9000/
SSLEngine Off
</VirtualHost>
What wonders me if this is problem of http to https redirection. Like I mentioned above I'm redirecting all traffic from 80 WAN to 443 Nas on router. Do I need to use mod_rewrite in that case if so, how it should be configured?
