bbaraniec
May 17, 2011Luminary
SABnzbget+sickbeard+couchpotato reverse proxy https-http
Current setup: HTTP disabled, HTTPS enabled on Pro. On router redirected port 443 to local IP of nas Public share accessible via https://mydomain.com but without forwarding 80 I get timeout. When ...
bbaraniec
Jul 25, 2011Luminary
sphardy wrote:
TeknoJnky wrote:
why don't you simply port map the programs you want in your router then add the ports to your url
Go back to the original post - it relates to forcing an HTTPS connection which you can't do purely via port forwarding
And also restrictions @work
