bbaraniec
May 17, 2011Luminary
SABnzbget+sickbeard+couchpotato reverse proxy https-http
Current setup: HTTP disabled, HTTPS enabled on Pro. On router redirected port 443 to local IP of nas Public share accessible via https://mydomain.com but without forwarding 80 I get timeout. When ...
bbaraniec
Jul 25, 2011Luminary
@TeknoJnky - yes, right now I'm accessing it via http and it's not loading
@sphardy - ok but your example is clear as http defines you what port you will be using. Let's maybe focus on proxy alone, if I get this thing to work then I will try SSL.
The article you linked above is great, actually something I'm looking for the "problem" is that it hast to be old. There are files named HTTP.pm but none of them is even near SBS.
