euphos
Sep 03, 2014Aspirant
Seagate Error codes
Two of my drives in my 104 are having problems. One that died I checked with SeaTools, and it failed to run the tests and cameback with an error code E161CB4A. Anyone know what this means? A search...
mdgm-ntgr
Sep 03, 2014NETGEAR Employee Retired
You should ask SeaGate what the error code means. Did SeaTools also give you an indication as to what they suggested you should do (e.g. if they suggested you should RMA the drive)?
When you say the drives were having problems, what problems were they having exactly? SMART errors? Something else?
If you need to buy new drives I would suggest considering SeaGate NAS drives, WD RED drives etc.
- Jan 17, 2016Retired_Member
