euphos
Sep 03, 2014Aspirant
Seagate Error codes
Two of my drives in my 104 are having problems. One that died I checked with SeaTools, and it failed to run the tests and cameback with an error code E161CB4A. Anyone know what this means? A search...
euphos
The first disk had problems a month or so ago and just died (slot#3). No error that I saw, but I didn't generate any log to investigate further. That disk was then replaced. Then about 3 weeks ago I started getting a bunch of reallocated sector counts on the disk in slot#4. Then they stopped. However The 104 is my media server, and I've been getting a lot of studdering playing videos. The error code came from the drive that died. I'm still running SeaTools on the second drive. The reallocated sector count was high enough that It need to be replaced I've been told.
Already have another drive to install. Purchased (2) ST400DM000 to use and upgrade my storage space. Luckily both of the bad drives are under warranty. Just never had to RMA drives before. These were purchased separate from the RN104.
- Jan 17, 2016Retired_Member
