chelsel
Aug 13, 2008Aspirant
Seagate ST31500341AS 1.5TB
Any idea when this will be supported :-)
Cliff
Cliff
- spudz72Aspirant
contempt wrote: I posted on the compatibility thread asking if there was official compatibility before I found this thread. Wondering if anyone has had any problems with these drives?
FYI, ZipZoomFly.com has them for $179.99. Was going to order 4 and upgrade all my 750GB drives.
I'm still awaiting an official answer myself... - schwerdAspirantI think so far, we're all waiting for an official answer....I have 2 drives...was going to put one in my Drobo and one in my ReadyNAS and see what happens
- zxgatesAspirantI don't know about offical compatability, but the 3 Seagate 1.5tb drives in my system didn't work until I upgraded to the latest firmware, and now I have three 1.5tb drives that work perfectly. Have written and erased a tb of data a couple of times with no issues. getting a 4th drive tomorrow and will see how the expansion goes.
Kudos for getting an updated firmware out so quickly to support these drives! - jmirabilAspirantAnyone yet successfully loaded four ST31500341AS 1.5TB drives into a Readynas NV+ and obtained a fully operational ~4.5TB xraid drive?
Does not look like it yet... Any capacity "screenshots"? I'm curious to see what the max capacity and (typical/max) drive temps are under xraid! Hopefully these drives are faster than the green power drives which seemingly cannot suspend-but it's no big deal really to me.
Currently weighing whether to go with 1TB GP drives or try these new 1.5TB drives...
Dare I ask if the 4 disk array can sleep and resume on demand <ducking> as those drives must suck down the juice to all spin 24x7
the race is on....thx! - Han_SoloTutor
jmirabil wrote: Anyone yet successfully loaded four ST31500341AS 1.5TB drives into a Readynas NV+ and obtained a fully operational ~4.5TB xraid drive?
Dare I ask if the 4 disk array can sleep and resume on demand <ducking> as those drives must **** down the juice to all spin 24x7
We just placed them on our compatibility list. We still however need to place a note indicating that firmware 4.1.4 or newer is required to use these drives. - Blues11LuminaryI purchased a new ReadyNAS NV+ a couple of weeks ago with 2 750GB drives. I kept it in X-RAID and loaded ~100GB of data onto it.
Then I purchased 3 of the Seagate 1.5TB drives. I added two in the two empty slots and it went for hours to initialize them. I then took out one of the 750GB drives and replaced it with my third 1.5TB. All was according to what I expected. The Volume Settings page showed 1 698 GB Seagate with 694 GB allocated and 3 1397GB Seagates with 694 GB allocated. All my data was there.
I then removed the 1 smaller drive (in slot 1) and after rebooting several times it's still not understanding that it's supposed to expand. It shows:
Disk space: 101 GB (4%) of 2076 GB used
Additional 5 GB reserved for snapshots
Configuration: X-RAID (Expandable RAID), 4 disks
Status: Not redundant. A disk failure will render this volume dead.
RAID Disks:
Ch. 1: UNKNOWN [698 GB]
Ch. 2: Seagate ST31500341AS [1397 GB] 694 GB allocated
Ch. 3: Seagate ST31500341AS [1397 GB] 694 GB allocated
Ch. 4: Seagate ST31500341AS [1397 GB] 694 GB allocated
Does anyone know how to make it forget about the fourth drive and give me 3 1.5 X-RAID drives for ~2700 GB?
Thank you. - bollarAspirant
I have.
Disk space:
2423 GB (58%) of 4163 GB used
RAID Configuration
Status: Redundant
RAID Disks:
Ch 1 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 2 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 3 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
Ch 4 : Seagate ST31500341AS [1397 GB] 1393 GB allocated
I was having a problem about a day after the installation where I couldn't delete a file. I decided to reboot with a file/quote check and that failed with a kernel panic. I restarted and it proceeded to do a resync and has been fine since. I did notice a sector reallocation on one of the drives, which I presume was the cause of the problem. - Balders1AspirantWhat you've done is broken the array. You've expanded to 4 drives by placing the additional 2 drives in the two empty slots. You should have replaced the 750GB drives 1 at a time.
You cannot move from 4 drives to 3.
You have two options:
1) leave the 750GB in and do without the additional space the 1.5TB drives give you.
2) buy an extra 1.5TB to replace the 750GB you've taken out.
BaldersBlues wrote: I purchased a new ReadyNAS NV+ a couple of weeks ago with 2 750GB drives. I kept it in X-RAID and loaded ~100GB of data onto it.
RAID Disks:
Thank you. - Balders1AspirantActually, there's a 3rd option which you probably won't want to do - blast it and start over, losing all your data on the drives. Backup first, reconfigure, restore.
Balders wrote: What you've done is broken the array. You've expanded to 4 drives by placing the additional 2 drives in the two empty slots. You should have replaced the 750GB drives 1 at a time.
RAID Disks:
Thank you. - jmirabilAspirant
bollar wrote: jmirabil wrote: Anyone yet successfully loaded four ST31500341AS 1.5TB drives into a Readynas NV+ and obtained a fully operational ~4.5TB xraid drive?
I have.
Disk space:
RAID Configuration
Status: Redundant
RAID Disks:
Wow! bollar you have given me the new drive to stash away $800 for these four drives, and then swap them in one at a time into my existing 4TB WD Greenpower array.
4.163 redundant Tb.. sweet. Thanks for the thorough report...
Is that normal to see te 4Gb discrepancy per drive -- [1397 GB]vs. 1393 GB allocated ?
What kind of drive temperatures do you see at idle and under higher load? That was my (and dare I say others') last basic curiousity...
