Danj864
May 13, 2020Aspirant
Search does not work on 516 or 628 6.10.3 Windows 10 Pro
Search does not work. Have reconfigured several times. Systems shows indexing, however after indexing, search still does not work. The RN 516 atcually has 6 Bays with 16TB drives in each bay....
Danj864
May 20, 2020Aspirant
I am attempting the search from within the NAS. I have completed the "settings" several times.
Maybe a screenshot from a NAS what has a working search function showing services selected would be beneficial.
Thanks for your response.
Dan
May 20, 2020Guru - Experienced User
I haven't had the best luck with that feature either, it tends to time out on me sometimes. In the past I saw some errors in the tracking log files in the log zip - I disabled the tracking and then re-enabled it - rebuilding the index. I'm not seeing that now, but I think you should check for that.
As far as settings go, I'm using the default settings for "Advanced". General settings are "Enabled" and "Content Indexing", but "Enable Indexing Numbers" is not.
