sunsina's avatar
sunsina
Guide
Oct 23, 2014
Secure Connection to PyDio (forcing https)
After installing pydio on ReadyNAS through WebGUI, I want to force the pydio GUI be only available over https on port 7127 and any http:7126 connection gets forced directed to https:7127.
The pydio webserver configuration files are installed in (/apps/pydio) directory.
/apps/pydio/http.conf
/apps/pydio/https.conf
After googling and merging a few solutions I modified
http.conf as follows
<VirtualHost *:7126>
ServerName localhost
KeepAlive Off
RewriteEngine On
#RewriteCond %{HTTP_HOST} ^[^\./]+\.[^\./]+$
RewriteRule ^/(.*)$ https://%{HTTP_HOST}/$1 [R=301,L]
</VirtualHost>
and the https.conf is as follows
<VirtualHost *:7127>
ServerAdmin [email protected]
SSLEngine on
SSLCertificateFile /etc/ssl/certs/pydio_sina.pem
SSLCertificateKeyFile /etc/ssl/private/pydio_sina.key
DocumentRoot /apps/pydio/web
<Directory "/apps/pydio/web">
Options FollowSymLinks
AllowOverride Limit FileInfo
Order allow,deny
Allow from all
</Directory>
ErrorLog /apps/pydio/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /apps/pydio/pydio_access.log combined
</VirtualHost>
In the apache2 webserver
After executing #apache2ctl -k restart I get following error and none of the http/https web servers works
apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.2.41 for ServerName
While the file /etc/hosts contains following line
127.0.0.1 localhost
I would be happy someone show me a better way to solve this problem?
If I should change the contents of any file add/remove some lines I want to know the absolute path of those files.
Thanks
  • In the /etc/apache2/sites-enabled I have just a file "090-pydio.conf" (which is a link) to /apps/pydio/http.conf
    I am not sure if the line "RewriteRule ^/(.*)$ https://%{HTTP_HOST}/$1 [R=301,L]" in the http.conf does mention that it must listen to port 7127?
    Shall I change it to "RewriteRule ^/(.*)$ https://%{HTTP_HOST}:7127/$1 [R=301,L]"
    When I execute apache2ctl -k restart I get following error
    Syntax error on line 1 of /apps/pydio/https.conf:
    <VirtualHost> cannot occur within <VirtualHost> section
    Action '-k restart' failed.
    The Apache error log may have more information.
    While I have no clue where the apache2 error log file is stored!?
ProSupport for Business
