camelxx
Nov 28, 2014Aspirant
Setup for 314 with WD Red 6 tb
I'm considering picking up the 314 4 bay with 4x 6tb WD red drives. Couple of questions please: 1) for XRaid2, will I have 18 gigs avail. as 1 volume? 2) If I go for the 516, Can I initially build...
mdgm-ntgr
Dec 04, 2014NETGEAR Employee Retired
You go to the Volumes tab and you should see a X-RAID button at the far right. Click on this and confirm you wish to disable X-RAID.
Select the volume, click on the settings wheel and select DESTROY.
